Starting and Stopping Metered Service Matrix
The following matrix is representative of how a metered SP type's field activity type profile would look. The following points describe the rows, columns and cells in the matrix:
  • The customer events represent the three start and stop events that may take place at the service point.
    • Start service is the event that takes place when a service point is to be started and the system has no knowledge of a related stop event.
    • Stop service is the event that takes place when a service point is to be stopped and the system has no knowledge of a related start event.
    • Start/stop service is the event that takes place when a service point is to be stopped for one customer and started for another at the same time.
  • The SP conditions represent the state of service at a service point. The following conditions are represented:
    • A device (the meter) is either installed or not installed.
    • The installed device is either turned on or off.
    • The source of service (the line or pipe) is either connected to the service point or disconnected.
    • If the source is disconnected, define a field activity for each potential disconnect location.
  • Each cell in the matrix represents a field activity to be created by the system for the combination of customer event and service point condition.
SP Condition
Customer Event:
Start Service
Customer Event:
Stop Service
Customer Event:
Start/Stop Service
No Device / SP Disconnected at meter
Install meter and connect line
N/A - no field work is necessary because the meter should have been read when it was removed
N/A
No Device / SP Disconnected at pole
N/A
No Device / SP Connected
Install meter
N/A
Device Installed / Device Off / SP Disconnected at meter
Connect line and turn on meter
N/A - no field work is necessary because the meter should have been read when the service was severed
N/A
Device Installed / Device Off / SP Disconnected at pole
N/A
Device Installed / Device Off / SP Connected
Turn on meter
N/A - no field work is necessary because the meter should have been read when the meter was turned off
N/A
Device Installed / Device On / SP Connected
Read meter
Turn off meter
Read meter
Device Installed / Device On / SP Disconnected at meter
Connect line and read meter
N/A - no field work is necessary because the meter should have been read when the line was disconnected
N/A
Device Installed / Device On / SP Disconnected at pole
N/A
