Setting Up Provider Configuration Options
This portal is used to maintain Provider Configuration Options.
You can access the portal from Admin > Open Market > Provider Configuration Option.
The following zones may appear as part of the portal's Main page:
  • Provider Configuration Option List zone lists all Provider Configuration Option records. Broadcast a record to display the details of the selected record.
  • Provider Configuration Option zone provides information about the selected Provider Configuration Option.
  • Market Provider Configuration Options zone lists the existing Market Provider Configurations for the selected Provider Configuration Option. Maintenance actions are available on this zone.
