Billing Data Extracts: Batch Controls
The billing data extraction process uses a set of batch processes to create data synchronization requests and extract files.
Creating Initial Synchronization Requests
- Bill Data Initial Load for DataConnect (C1-BLDIL)
- Bill Segment Data Initial Load for DataConnect (C1-BSDIL)
- Billing Data Initial Load for Legacy DataConnect (C1-BLEIL)
These batch processes should be run to create initial load data synchronization requests based on the sync business objects described above.
Creating Extract Files
- Bill Data Extract for DataConnect (C1-BLDTX)
- Bill Segment Data Extract for DataConnect (C1-BSDTX)
- Billing Data Extract for Legacy DataConnect (C1-BSYEX)
These batch controls are defined as values for the Batch Control for Extract algorithm parameters on the Pre-Processing algorithms on the sync business objects described above.
- Bill Seg Lines Extract - DataConnect (C1-BSLDX)
- Bill Segment SQ Extract - DataConnect (C1-BSSQX)
Use the Batch Control portal for more information about these batch controls. The extract batch controls contain parameters that can be used to specify details (including path and file name for this file) for a delimited flat file containing extracted data.
