Hidden Filters
Data explorer zones include the ability to define Hidden filters to restrict the rows and / or columns that appear in the zone. The following are the potential sources of a hidden filter's value:
  • The global area contains the fields whose values are maintained in global context.
  • The portal area contains the fields describing the object currently displayed in a portal.
  • Other zones on a portal can broadcast information to the portal area, which can then in turn be used by the zone as a hidden filter.
These parameters are applicable to the zone types
  • Info Data Explorer - Multiple SQLs (F1–DE)
  • Query Data Explorer - Multiple SQLs (F1–DE-QUERY)
  • Info Data Explorer - Single SQL (F1–DE-SINGLE)
A hidden filter is defined using the following mnemonics:
Mnemonic
Description
Valid Values
Comments
name=
This mnemonic defines the name of the field that needs to be broadcast from other zones or populated in the portal context
FIELD_​NAME
datasource=
This mnemonic defines the source of the hidden filter's value.
If this mnemonic is left blank, the default behavior is as follows:
- If the field has been broadcast from another zone, the broadcast value is used.
- If no value is broadcast, the portal context is checked to determine if this field exists (if so, its value is taken).
- If still no value, the global context is checked.
- If still no value, the zone appears as per the poprule mnemonic.
G
Indicates that the zone should look for the filter value in global context.
P
Indicates that the zone should look for the filter value in portal context.
D
Indicates that the zone should look for the filter value in the page data model.
poprule=
This mnemonic controls what happens if the hidden filter is not present.
R
Indicates that a value for the filter is required. The zone will be set to the "empty state" and the "please broadcast" message will appear in the zone. This is the default value.
O
Indicates that the value is optional. If no value is required, the zone is still built without that value.
type=
Defines the visual metaphor used to capture the filter values.
DATE
Filters of this type capture a date.
DATE/TIME
Filters of this type capture a date and time.
STRING
Filters of this type capture a string
MONEY
Filters of this type capture a monetary field. This type of filter must also reference the cur mnemonic.
NUMBER
Filters of this type capture a numeric field. This type of filter may also reference the decimals mnemonic.
LOOKUP
Filters of this type capture a lookup value. This type of filter must also reference the lookup mnemonic.
TABLE
Filters of this type capture an administrative table's value (code and description). This type of filter must also reference the table mnemonic.
CHARTYPE
Filters of this type capture predefined characteristic values for a characteristic type (code and description). This type of filter must also reference the chartype mnemonic.
ASIS
Filters of this type capture a list of values to be referenced within an 'IN' clause within the SQL statement.
label=
Defines the filter's label that appears in the zone's description bar.
FIELD_​NAME
Enter a valid field name whose label should be used. This should always be the option used if multiple languages are needed.
'text'
Defines the text directly.
cur=
Defines the currency code applied when type=MONEY.
CURRENCY_​CD
Enter a reference to a valid currency code.
dec=
Defines the number of decimal places when type=NUMBER.
N
It is optional. If provided it should be an integer. If not provided, the number of decimals will default to the number of decimal places defined on the currency code specified on the installation record.
lookup=
Defines the lookup flag whose values appear when type=LOOKUP.
LOOKUP_​FIELD_​NAME
Enter a reference to a valid lookup field name.
table=
Defines the admin table whose values appear when type=TABLE.
TABLE_​NAME
Enter a reference to a valid admin table name.
chartype=
Defines the characteristic type code whose values appear when type=CHARTYPE.
CHAR_​TYPE_​CD
Enter a reference to a valid characteristic type code.
searchField=
This mnemonic controls the initial population of the filter when the zone is launched as a search from a UI map.
FIELD_​NAME
Enter the field name that exactly matches the searchField name specified in the oraSearchField html element in the UI map.
