Examples of Badged Lamp-Oriented Activity Types and their Steps
The following table shows several classic lamp-oriented activity types and their respective steps:
Activity Type |
Step |
Step Type Action |
Connect SP and install lamp |
Connect SP to power source |
Connect Service Point |
Install lamp |
Install Item |
Attempt to notify owner - optional |
Contact Customer |
Connect SP |
Disconnect SP |
Disconnect SP from power source |
Disconnect Service Point |
Install lamp |
Install lamp |
Install Item |
Remove lamp and leave connected |
Remove lamp |
Remove Item |
Install eye |
Install eye |
Turn On Item |
Remove eye |
Remove eye |
Turn Off Item |
Remove and disconnect lamp |
Verify premise is vacant - optional |
Contact Customer |
Remove lamp |
Remove Item |
Disconnect warning |
Place disconnect warning |
Contact Customer |
Reconnect lamp |
Install eye - optional |
Turn On Item |
Install lamp - optional |
Install Item |
Cut lamp for non payment |
Remove eye - optional |
Turn Off Item |
Remove lamp - optional |
Remove Item |
