Extract FA Information
When XAI processes the outgoing messages generated by the sample FA integration algorithm, it builds the XML request by calling the service referenced on the NDS type's XAI inbound service.
The base product provides a service, called CIPOEFIP, which extracts field activity information along with information related to the service point, meter, item, premise and account for the field activity (if applicable). If this service does not provide the functionality required by your implementation, you may create your own version using this one as a basis.
Note that this service defines an input parameter to exclude Financial Information. You can set this to Yes to avoid the account financial information (see below).
The following tables list the data that is extracted.
| FA Type information |
| All fields in the main FA Type table and the corresponding language table |
| FA Type Characteristics |
| FA Information |
| All fields in the main Field Activity table |
| Status description |
| Cancellation Reason description |
| FA Steps collection |
| FA Characteristics. Note the service limits the number of field activity characteristics that it extracts. It only extracts the first 100. |
| Appointment information |
| SP Type information |
| All fields in the main SP Type table and the corresponding language table |
| SP Type Characteristics |
| SP Information |
| All fields in the main Service Point table |
| Source Status description |
| Disconnect Location description |
| SP Location description |
| Facility Level 1, 2 and 3 descriptions |
| SP Operation Area and Description for the FA type's field service class |
| SP Multi-Item collection |
| SP Equipment collection |
| SP Characteristics |
| SP Geographic Data |
| SP Operation Area collection |
| Premise Information |
| All fields in the main Premise table |
| Premise Type description |
| MR Warning description |
| MR Instructions description |
| Life Support/Sensitive Load flag description |
| Alternate Address collection |
| Landlord Agreement Description |
| Name of Landlord's main person |
| Phone Number collection of Landlord's main person |
| Premise Characteristics |
| Premise Geographic Data |
| Meter Information for the meter currently installed at the Service Point (if applicable) |
| All fields in the main Meter table |
| Meter Type description |
| Meter Status description |
| Manufacturer description |
| Model description |
| Meter Id collection |
| Meter Characteristics |
| Meter Equipment collection |
| Meter Configuration Information for the meter currently installed at the Service Point (if applicable) |
| All fields in the main Meter Configuration table |
| Meter Installation Date/Time |
| Calculated High / Low limit for the meter on the FA schedule date |
| Item Information for the badged item currently installed at the Service Point (if applicable) |
| All fields in the main Item table |
| Item Type description |
| Item Status description |
| Model description |
| Item Characteristics |
| Item Equipment collection |
| SA Information for the first two Service Agreements found for the service point |
| SA ID |
| CIS Division / SA Type |
| Account ID |
| SA Status |
| Start Date / End Date |
| Customer Read Flag |
| Rate Schedule |
| SA / SP collection |
| Customer Information for the account(s) linked to the above service agreements |
| All fields in the main Account table |
| Person ID of the main person |
| Name of the main person |
| Person / Business flag for the main person |
| Life Support / Sensitive Load flag, flag Description and Description for the main person |
| Phone Number collection for main person. Note, this information may be overridden if a phone number is entered on the field activity. |
| The following financial information is not extracted if the input Exclude Financial Information is set to Yes. |
| Credit Rating Points. Calculated from the Beginning Credit Rating on the Installation Record or the account’s CIS Division and CR_RATING_PTS from CI_ACCT_CR_R_VW |
| Cash Only Points. Cash Only Points. Calculated from the Beginning Cash-Only Score on the Installation Record or the account’s CIS Division and CASH_ONLY_PTS from CI_ACCT_CR_R_VW |
| Current Amount (calculated from FT information) |
| Payoff Amount (calculated from FT information) |
| Disputed Amount (calculated from FT information) |
| Arrears Information: Disputed Amount, New Charges, 30 days old, 60 days old, 90 days old |
| Count of the number of bills generated in the last 6 Months |
| For each bill: |
| Bill ID |
| Bill Date |
| Bill Amount |
| Meter Read information for the last Bill |
| All fields in the main Meter Read table |
| Register Read collection |
| Count of the number of payments generated in the last 6 Months |
| For each payment: |
| Payment ID |
| Payment Event ID |
| Payment Date |
| Payment Amount |
| Cancel Reason and its Description |
