Physical Attributes of a Classic TOU Map
When defining a classic TOU map, there are basic attributes, which need to be defined:
  • The collection of possible time of use codes to which the data will be mapped. These are grouped together into a TOU group.
  • Minutes per Interval
  • Is this data owned by a service agreement or is it common data?
These are physical attributes of the data and have nothing to do with the business purpose of the data. This information is defined on the classic TOU Map Type.
The classic TOU map type may also include an algorithm used to automatically create data for the classic TOU map .
This is the same model used for interval profile data. Refer to Physical Attributes of Interval Data for more information.
