Setting Up Application Services
As described under Access Rights, you can prevent unauthorized users from accessing cases. The following points describe how to implement this type of security:
  • Create an application service for each case type that needs to be secured
  • Create an action on the application service for each status you need to secure
  • Link the valid user groups to the application service and define which actions they can perform
  • Define the application service on the case type
  • Define the related action for each status on the case type / status
