MDL - Create Download Flat File
This process reads all download staging records marked with a given batch control ID & run number and creates the flat file that's passed to the meter read software.
Note: This process is rerunnable. You can reproduce the flat file at any time. Simply request this job and specify the run number associated with the historic run.
If you require different flat file formats or different routing methods, you will need to create additional versions of this program. Refer to Setting Up Meter Read Extracts for instructions describing how to add another process.
