Usage Requests
The information in this section applies to the integration with Oracle Utilities Meter Data Management.
Usage request records are created when bill determinants are requested from Oracle Utilities Meter Data Management during billing. The consumption information is then used to create a bill segment for the associated service agreement.
Refer to The Big Picture of Usage Requests for more details
Use Menu > Usage > Usage Request to open this page. When you select a usage request record, the maintenance portal opens and displays the associated information for the usage request record. You can also navigate to the maintenance portal from the Bill Segment - Usage page.
Refer the embedded help on this portal’s zones for more information.
