Notification Download Staging - Characteristics/Context
This page displays the characteristics and/or context associated with the download staging record. Refer to NDS contains interesting data for more information.
Open this page using Menu > Workflow and Notification > Notification Download Staging > Search and navigate to the Characteristics/Context page.
Description of Page
The Download Staging ID is the unique identifier of the notification download staging (NDS) record.
If Characteristics are used by the algorithm that created this record, to record information related to the record, this grid displays the Characteristic Type and Characteristic Value for each entity associated with the download staging record.
If Context entries are used by the algorithm that created this record, to record information related to the record, this grid displays the Context Type and Context Value for each entity associated with the download staging record.
The values for Context Type are customizable using the Lookup table. This field name is NT_​DWN_​CTXT_​FLG.
