Examples of Badged Lamp-Oriented Activity Types and their Steps
The following table shows several classic lamp-oriented activity types and their respective steps:
Activity Type
Step
Step Type Action
Connect SP and install lamp
Connect SP to power source
Connect Service Point
Install lamp
Install Item
Attempt to notify owner - optional
Contact Customer
Connect SP
Disconnect SP
Disconnect SP from power source
Disconnect Service Point
Install lamp
Install lamp
Install Item
Remove lamp and leave connected
Remove lamp
Remove Item
Install eye
Install eye
Turn On Item
Remove eye
Remove eye
Turn Off Item
Remove and disconnect lamp
Verify premise is vacant - optional
Contact Customer
Remove lamp
Remove Item
Disconnect warning
Place disconnect warning
Contact Customer
Reconnect lamp
Install eye - optional
Turn On Item
Install lamp - optional
Install Item
Cut lamp for non payment
Remove eye - optional
Turn Off Item
Remove lamp - optional
Remove Item
