The Periodic Processes
The following diagram illustrates the dependencies between the periodic background processes. While many of these processes should be run at least on a monthly basis, you may want to consider running them more frequently (depending on business requirements).
While many of the periodic background processes should be run at least on a monthly basis, consider running these more frequently or depending on business requirements.
The mnemonics in the boxes refer to the individual batch processes described above.
Few dependencies exist. As you can see, there are few dependencies between the boxes (meaning they may be run in parallel).
