Setting Up Contract Option Event Types
Contract Option Event Type defines control information required for contract option events. Open
to define your contract option event types.This page will not be available if Complex Billing module is turned off.
Description of Page
Enter a unique Contract Option Event Type code and Description.
Indicate the Contract Option Type for this event type.
Use the Characteristics collection to define characteristics that can be defined for contract option events of this type. Use Sequence to control the order in which characteristics are defaulted. Turn on the Required switch if the Characteristic Type must be defined on contract option events of this type. Enter a Characteristic Value to use as the default for a given Characteristic Type when the Default switch is turned on.
