Setting Up Classic TOU Map Relationship Types
Classic TOU Map Relationship Types define the role that a classic TOU Map will serve for a customer. Open Admin > Consumption > TOU Map Relationship Type > Add to define your classic TOU map relationship types.
This page will not be available if Complex Billing module is turned off.
Description of Page
Enter a unique TOU Map Relationship Type ID and Description for the TOU map relationship type.
Enter the TOU Map Type collection. This is a list of valid TOU map types whose collections of data can serve the role defined by the TOU map relationship type.
To aid in setup, the map type is not a required field on this user interface. This will help you to define your high level map relationship types first and then define the more detailed map types. The valid map types will need to be linked to the appropriate relationship types prior to creating service agreement TOU maps.
