Billing For Loans And Interest Calculation
A bill segment is produced for a loan when its service agreement's account is next billed.
Factors on a loan's SA type controls when a bill segment is produced for a loan. Typically SA types for loan service agreements are set up to use anniversary calendar billing. For this configuration:
  • You must indicate the type of anniversary billing in the calendar billing option. Currently, we only support the Anniversary Future Billing (meaning that loans are billed in advance just like a classic home loan is). Refer to Using The Anniversary Method for more information about how this billing method controls the end date of the loan bill segment.
  • You must reference an anniversary billing frequency consistent with the recurring charge frequency (e.g., monthly, quarterly, etc.).
To set up for a loan that is billed on a monthly basis, you would define the following fields in SA Type - Billing:
  • Use Calendar Billing: Anniversary Future Billing
  • Anniversary Bill Frequency: Monthly
  • Total Bill Amount: Required
  • Recurring Charge: Required
  • Recurring Charge Frequency: Monthly
  • Total Amount To Bill Label: Loan Amount
  • Recurring Chg Amt Label: Payment Amount
If your type of loan must be billed on an exact date (for example, always on the 15th of the month) or with an exact number of days between each bill (for example, every 14 days), then your loan should be set up to use the calendar billing option of Use Bill Period. In order for your loan bills to be created on specific dates, the system makes the following assumptions:
  • Your bill cycle schedule for the loan's account is defined with the dates that you want the loan to bill and is defined with the window start date equal to the window end date.
  • You define a bill period schedule corresponding to your bill cycle schedule. Each bill period schedule's bill date should match your bill cycle window start date and each bill period schedule's bill segment end date should be set to the loan period end date.
  • Considerations for the first bill. If the loan SA Type's Initial Start Date Option indicates that the first day of the service agreement should be billed, then the loan SA's start date should match the window start date of the next bill cycle schedule for the account. If the loan SA Type's Initial Start Date Option indicates that first day of the service agreement should not be included, then the loan SA's start date should be one day prior to the window start date of the next bill cycle schedule for the account.
  • Define your recurring charge frequency to match the frequency of your bill periods.
How the bill segment affects the customer's balance, and how it affects the general ledger are controlled by several algorithms defined on the loan service agreement's SA type and bill segment type:
  • The SA type's loan schedule algorithm controls how the loan amortization schedule is calculated.
  • The SA type's loan interest charge algorithm controls how interest is calculated.
  • The bill segment type's create algorithm controls how the bill lines are constructed.
  • The bill segment type's financial algorithm controls how the general ledger is affected by the bill.
The second entry in the following table contains an example of the financial transaction produced by the base package algorithms (note, the first financial transaction in the table was described under Booking The Principal Amount Using An Adjustment ).
Event
GL Accounting
Effect On Current Balance
Effect On Payoff Balance
Current Balance
Payoff Balance
Loan service agreement is activated
Long Term Loan Receivable 10000
Cash <10000>
0
10,000
0
10,000
long-term: 10,000
First bill segment is produced
Interest:
Long Term Loan Receivable 41.66
Interest Revenue <41.66>
Transfer Long Term To Short Term:
Short Term Loan Receivable 438.71
Long Term Loan Receivable <438.71>
438.71
41.66
438.71
10,041.66
short-term: 438.71
long-term: 9,602.95
Several important points are illustrated above:
  • When a bill segment is produced for a loan service agreement, the following takes place (if you use a bill segment creation algorithm of Create Bill Segment for Loans ):
    • The loan SA type's bill segment creation algorithm calls the SA type's loan interest charge algorithm.
    • The base package loan interest charge algorithm calculates simple interest based on: 1) unbilled principal (i.e., the service agreement's payoff balance minus the current balance), 2) the number of billing periods covered by the bill, and 3) the interest rate. Refer to the algorithm type LINT-SI for more information about the base package interest calculation algorithm.
No interest on interest and no interest on past due amounts. Just like a classic home loan, the base package algorithms do not calculate interest on interest, nor do they calculate interest on past due amounts. If you want to levy a late payment charge, use the SA type's late payment processing. If your organization calculates interest differently, you must develop your own algorithm(s).
  • The SA type's bill segment creation algorithm uses the calculated interest to format the bill segment's bill lines. It creates one bill line to show the amount of interest in the payment, and another bill line to show the amount of principal. The principal amount is equal to the service agreement's periodic payment amount minus the amount of calculated interest.
  • The financial transaction illustrated above is created if you use a bill segment financial algorithm of Payoff Amt = Interest / Current Amt = Bill Amount on the loan's bill segment type. The following explains how this algorithm works:
    • The SA's current balance increases by the amount of the loan's periodic payment amount (i.e., its recurring charge amount). In other words, the amount the customer thinks they owe increases by 438.71.
    • The SA's payoff balance increases by the amount of interest. In other words, if the customer wanted to payoff the loan, they'd owe 10,041.66.
    • The Interest portion of the GL accounting is straightforward (if you're an accountant). It simply takes the amount of interest and debits it to the SA type's receivable distribution code (long-term receivables) and credits it to the distribution code defined on the interest rate's bill factor (typically interest revenue).
    • The Transfer portion of the GL accounting transfers moneys from long-term receivables (i.e., the unbilled principal) to short term receivables (the billed portion of the debt). The amount transferred is equal to the FT's effect on the service agreement's current balance, allowing the general ledger to differentiate between unbilled loan receivables (long term) and billed loan receivables (short term). Remember that the payoff balance is the net of the short-term and long-term receivables.
