Rounding At the End
The following is an example of a simple bill segment with three bill lines.
This illustrates a simple bill segment with three bill lines. The first two bill lines are calculated using simple rate components that have a precision of .01. The last bill line rounds the bill up to the next highest 0.05. To calculate the last bill line, the rate component must an exact charge rate component and its value would be calculated using a value calculation algorithm that sums the first two rate components and rounds them up to the nearest .05.
The first two bill lines are calculated using simple rate components that have a precision of .01. The last bill line is special, it rounds the bill up to the next highest 0.05 (this is an example from a country that doesn't have cents, their smallest coin is 0.05). The following would be necessary to calculate the last bill line:
  • The rate component would be an exact charge rate component
  • Its value (i.e., the exact charge) would be calculated using a value calculation algorithm that sums the first two rate components and rounds them up to the nearest .05. Refer to the RCVL-RNDXRF algorithm for a value calculation algorithm that can perform this function.
An alternative approach is to do the following:
  • Use a summary rate component to calculate the exact charge. This rate component would require the following characteristics:
    • FCPO
    • Non printing
    • Rounding type would be round up
    • Precision would be 0.05
    • Reference the summary rate component as the exact charge rate component's value
