Notification Download Staging - Main
Open this page using
Description of Page
The Download Staging ID is the unique identifier of the notification download staging (NDS) record.
Service Provider is the service provider to whom this download staging record will be sent. The description of the service provider is displayed adjacent.
Notification Download Type indicates the reason for this notification. The description is displayed adjacent.
Refer to Designing Notification Download Types for more information about notification download types.
The Processing Method indicates whether this record will be processed by a Batch extract process or through the XAI tool. The processing method defined on the Notification Download Profile will be used to populate this value.
If the processing method is Batch, then NDS Extract Process indicates the process that will extract this record. This value is populated based on the service provider's notification download profile. NDS Extract Run indicates in which batch run this record was extracted or will be extracted.
Refer to Designing Notification Download Profiles for more information about the NDS Extract Process.
The Retry Count is used by the XAI tool to keep track of how many times the tool tried to process this record and could not process the record, resulting in an error.
The Create Date/Time indicates the date and time that this record was created.
Status defines the state of the NDS record. This is only used when the processing method is XAI and will be protected when the processing method is Batch. Refer to Lifecycle of Notification Download Staging for more information.
This bottom of this page contains a tree that shows the various objects linked to the notification download staging record. You can use this tree to both view high-level information about these objects and to transfer to the respective page in which an object is maintained.
