Performance Target Metrics and Metric Types
The framework supports two types of metrics for performance monitoring:
  • Value based metrics are used to record results against a specific numeric target.
  • Time based metrics are used to track the results against a specific date and time target.
The list of valid metrics for a given performance target category and its associated performance target types is maintained using an extendable lookup. Framework uses the base business object Batch Performance Target Metric (F1-BatchPerfTargetMetric) to define batch process metric values. Refer to this lookup for the supported batch process metrics.
Note: While users are not prevented from adding new values to the lookup, the list is not intended to be extendable as new values will not be recognized by the business service that performs the base batch performance calculation logic.
Your edge product or implementation may supply other extendable lookup business objects for additional performance measurement use cases, if applicable.
