Favorite Scripts Zone
The Favorite Scripts zone lists the business process assistant (BPA) scripts that you have defined on your user preferences. You can click on a script to execute it. You can click the Search button in the zone to search for other scripts.
Note: If you do not see the Favorite Scripts zone in the sidebar, navigate to User Menu and click the Preferences menu item to display the User - Portal Preferences page. Under the Sidebar Portal row, select the Display option for the Favorite Scripts zone.
