Initial Consumption Period Considerations
Bill segments produced for a service agreement have two time periods:
  • The bill segment period. The bill segment period defines the entire period of time covered by a bill segment's charges.
  • The consumption period. The consumption period defines the period of time used to calculate the number of days for daily charges.
The consumption period almost always starts one day after the bill segment period. The consumption period always ends on the bill segment's end date. For example, a bill segment period that spans 5-Jan-2002 through 6-Feb-2002 will almost always have a corresponding consumption period of 6-Jan-2002 through 6-Feb-2002. The reason that the start dates don't match is because a bill segment's start date equals the end date of the prior bill segment (i.e., the start date was already counted in the previous bill segment's consumption period and we don't want to count it twice).
The only time when the previous paragraph isn't true is the first bill segment that's produced for a new service agreement. This is because different utilities count the first day of a new service agreement differently than others. Because of this, a flag exists on SA Type called Initial Start Date Option. This flag controls whether the service agreement's start date is included in the consumption period in a service agreement's first bill segment.
The following table describes the ramifications of the options you can set for this flag.
Flag Value
Consumption Period Calculation
Use This Option When
Add 1 Day Always
The consumption period's start date is calculated by adding 1 day to the service agreement's start date. (The SA start date is never included in the consumption period for the first bill segment.)
You want the initial bill and all subsequent bills to have a consistently calculated consumption period (i.e., the consumption period for the first and all other bills is always one day less than the bill segment's period).
Add 1 Day for Back-to-back
A back-to-back occurs when any service point for this service agreement was previously linked to a different service agreement that was stopped on the same date that the new service was started (i.e., there is no gap in the service).
If a back-to-back is detected, the consumption period start date is calculated by adding 1 day to the SA start date.
If no back-to-back is detected, the start date of the consumption period is the SA start date.
You want to flexibly handle consumption period calculation. If you start customers on the same date as the stop date of the previous customer, billing does not include the SA start date in the consumption period. However, if you start a new customer one day (or more) after the stop date of the previous customer, billing includes the first day of the service agreement in the consumption period.
Include First Day
The start date of the consumption period is the service agreement start date. (The SA start date is always included in the consumption period.)
You want to always include the first day AND you will never encounter a back-to-back situation.
The example below shows how the consumption period would be calculated with the various options for a customer who starts service on January 1.
First Bill
Meter Read: Jan 31
Bill Segment Period: Jan 1 to Jan 31
Second Bill
Meter Read: Feb 28
Bill Segment Period: Jan 31 to Feb 28
Third Bill
Meter Read: Mar 31
Bill Segment Period: Feb 28 to Mar 31
Consumption period using Add 1 Day Always
Jan 2 to Jan 31 ( 30 days)
Feb 1 to Feb 28 (28 days)
Mar 1 to March 31 (31 days)
Consumption period using Add 1 Day for Back-to-back when back-to-back is detected
Consumption period using Add 1 Day for Back-to-back when back-to-back is NOT detected
Jan 1 to Jan 31 ( 31 days)
Consumption period using Include First Day
There may be SA types for which the value of this flag does not affect the consumption period calculation and still other SA types where this flag is never used. For example,
  • For billable charge service agreements, the consumption period is equal to the start and end dates on the billable charge and therefore this flag is not applicable.
  • A sub SA either inherits the consumption period from the master SA or it uses billable charges. As a result, billing does not use this flag.
  • For some service agreements, the charges on the rate are not affected by the consumption period. For example, if you have a customer with a simple meter and a simple usage-based charge, billing calculates the amount of consumption between the start reading and end reading and applies the rate (i.e., the number of days in the consumption period doesn't impact the charges in some rates).
  • Some service agreements are not billed, for example, overpayment service agreements. For this type of service agreement and other types of service agreements that are not billed, this flag is not applicable. However, the system does not prevent a value from being entered in these cases to allow for an implementation process to use the flag if needed.
Setting this flag to an appropriate value is significant for certain types of service agreements.
  • For services whose rate includes daily charges, the configuration of this flag may impact the first bill segment for the service agreement. For example, if the first bill period is October 1st through October 31st, do you consider consumption period to be 31 days or 30 days? How you want to bill the customer on the first bill determines how you set this flag.
  • For interval billing service agreements, the interval usage recordings typically begin on the first day of service. If you add 1 to the start date, you miss billing for intervals on the first day. In this case, you should set the value to Add 1 Day for Back-to-back.
Fastpath:
Refer to Determine the Consumption Period for more information.
