Classic TOU Map Used For Mapping & Pricing
The classic TOU map used by the rate component for mapping is defined either directly on the rate component or it is linked to the service agreement.
- If ALL service agreements linked to the rate component's rate should use the same classic TOU map, then link the classic TOU Map to the rate component
- If some service agreements use different TOU maps than others, the TOU map must be linked to the service agreement. In this case, you must indicate a TOU Map Relationship Type on the rate component. The TOU map relationship type defines the business role of TOU map.
Refer to Sharing TOU Map Data for more information.
