Designing Notif. Download Types
You will need one notification download type for every type of notification your organization can send to service providers. To "design" your notification download types, list:
We have populated the Notification Download Type column with a few classic examples:
Download Type Condition Flag
Inform all parties that customer is stopping service
CUSTSTOP
Inform all parties that meter has been changed
METERCH
Send consumption history
Check if it's OK to switch customer from current supplier
Reject request
You should also consider the priority of each NDS type with respect to the other types.
Once you know the different types of download notifications, you have to determine the physical method used to route the notification to the third party. Refer to Designing Notification Download Profiles for how to do this.
If the outbound notification may be routed via XAI, you must define an XAI inbound service. This is used by the XAI MPL to retrieve information about the record related to the outbound message.
Fastpath:
Refer to Configuring the System for XAI Messages for more information on designing your XAI outgoing messages.
