Notification Download Type - Context
If the notification download staging record is communicated to the external system through XAI, the NDS context is used to help build the XML document.
Description of Page
The context collection functionality allows you to define a collection of Context Types that should be defined for a notification download staging record of this type. When the NDS record is created, with its collection of these Context Types, the Context Values would correspond to system data related to this NDS record. In addition, you may specify a Context Value if this is a constant value for NDS records of this type.
The XPATH is used by XAI NDS Types. For each context type, use the XPATH to indicate the relative path in the XML document where the field value will be placed when building the XML document.
Where Used
A Notification Download Staging record must reference a notification download type. Refer to Process X - Populate Notification Upload Staging for more information.
A Notification Download Profile references one or more notification download types. Refer to Setting Up Notification Download Profiles for more information.
