Maintaining Service Call Communications
A service call communications is used to process service call information gathered from interactions with the customer, the public or other external entity. These interactions can be reporting a new issue/request, adding comments to an existing issue/request or cancelation (issue is resolved or request no longer needed). Refer to Service Calls for background information on service calls.
To view and maintain service call communications, open Menu > Field Order > Service Call Communication > Search . You are brought to a query portal with options for searching for service call communications.
Once a service call communication record has been selected, you are brought to the maintenance portal to view and maintain the selected record.
The following zones are displayed:
  • Service Call Communication zone shows the details of the service call .
  • Questions zone shows the related questions and answers to the service call communication. This information is stored in the Response object.
Refer to the zones’ embedded help for more information.
