Register Data Set Key
When a system-generated key value is assigned to a record, you need to also store the key value in a key table that corresponds to the record's database table. The name of this table is CI_​REG_​DATA_​SET_​K. The following table describes each column on this table.
Column Name
Length
Req'd
Data Type
Comments
REG_​DATA_​SET_​ID
12
Y
A/N
This should be your newly created Register Data Set ID from above.
ENV_​ID
6
Y
N
This is the environment id defined on the installation options.
