How To Set Up Exact Charge Rate Components
There are no special additional fields on this page available for setting up an Exact Charge rate component. The following information will help you determine how to set up your Exact Charge rate components.
Select a Value Type of Charge.
Refer to Rate Component - Main Information for information about defining the Value Source.
Enter the verbiage to appear on the customer's bill in Description On Bill and turn on the Print switch. Refer to How to use Description on Bill for more information about these fields.
Move to the Cross Reference window to define the rate components against which the exact charge will be applied.
Move to the GL Distribution window to define how any additional revenue associated with the minimum charge should be booked in the general ledger.
