Moving Positional Rows Up and Down
A rate component's sequence number controls the order in which the rate component should be applied. You may modify the order execution using the up and down arrows.
The sequences need to be renumbered in order to ensure the correct order. The fields Start from sequence number and Increment By are used to define the sequence number to assign to the first rate component and the subsequent values to assign to subsequent rate components.
