Apply To
Apply To calculation rules create bill lines that levy charges based on amounts calculated on other bill lines. Apply To calculation rules must define the respective target category that they are applied to. The calculation rule(s) that compute charges to which "Apply To" rules will be applied must be defined as members of the target category. See Cross-Reference under Common Parameters for more information about Member and Target categories.
- Rule Name: Apply To
- Base Package Calculation Rule Business Object: C1-ApplyTo
- Apply Calculation Rule Algorithm Type / Algorithm: C1-APPLYTO
Rule Parameters:
Calculation Details: Details regarding how the calculation
rule performs its calculations:
- Error If No Value: Indicates what should happen if the system cannot find any calculation rules that are members of the target category at billing time.
- Seasonal: See Common Parameters.
- Value Type: Defines if the price is a Charge, Percentage or Unit Rate.
- Value Source: specifies the source of the price. Depending on the value source selected, either a Bill Factor, Value, or Value Algorithm is required.
Example: The following calculation rule applies a
county tax other calculation rules that belong the "Taxable - County
Tax" category.
Calculation Group: Taxes
Calculation Rule: CNTYTAX
Sequence: 530
Description: County Tax
Description On Bill: County sales tax %R %T
Print: Yes
Print if Zero: No
Rounding Type: Nearest
Precision: 0.01
FCPO: No
Override Proration: No
- Error If No Value: No
- Seasonal: No
- Value Type: Percentage
- Value Source: Bill Factor
Bill Factor: County Tax
GL Distribution:
- Distribution Source Code: Specific Distribution Code
Distribution Code: Payable - County Tax
Cross Reference:
- Target Category (Category Type / Value): Taxable / County Tax
- Member Category (Category Type/Value): Summary Item / Summary Line
