Complete Oracle Utilities Initial Setup Tasks
Before you can use the Customer Experience for Utilities solutions, you must ensure that the related features are set up appropriately in your Oracle Utilities customer information system. The following table identifies each item that needs to be set up during the initial setup process, provides implementation details, and refers you to related documentation that can assist you.
All of the documentation listed below (unless otherwise noted) can be found in one of the following libraries the in the Oracle Help Center, along with additional information about using and configuring your Oracle Utilities customer information system:
| Task | Details | Documentation |
| Extendable Lookups |
Extendable lookups are used to control some items within the Oracle Customer Experience for Utilities solutions, such as:
The person synchronization is controlled by an F1-DataSyncControl extendable lookup business object of C1-CX4U-PERSON. The status of this lookup record must be active to enable the synchronization and the external system and message sender must be configured. |
See Defining Extendable Lookups in the Administration Guide |
| Data Synchronization |
Person data synchronization is used to trigger updates to the Oracle Customer Experience for Utilities and other Oracle systems when person record changes are made. To set up the synchronization, be aware that:
See:
Parent topic: Provision Your Oracle Cloud Applications
