Extended Field Configurations
The table below provides the extended field configurations that store the mapping of the extended fields of the Contact and Account objects between Fusion applications and your Oracle Utilities application.
Use the Fusion Model Extension to extend the Fusion Contact and Account data model to define new fields for the characteristic types, as needed. Then, in the utility configuration, under Extended Fields, provide the mapping between the Fusion applications fields and corresponding Oracle Utilities fields.
| Extended Field Data | Configuration | Comment |
Name: characteristics Description: Holds the extended fields mapping. |
Examples: "ccsValue": "C1-SVTKA", "faValue": "MyHobby"
"ccsValue": "C2MBTHDT", "faValue": "DateOfBirth"
"ccsValue": "C1-NICK", "faValue": "FavColor" |
Characteristics can be configured to store additional data in your Oracle Utilities system. Each extension field requires a Characteristic Type as the cssValue, which can be mapped to fixed fields delivered in the Fusion application schemas. |
Parent topic: View and Edit the Existing Configuration
