View and Edit the Existing Configuration
To meet the needs of your utility, you can view and edit the existing configuration.
To view the existing configuration:
Request URL: <CXIF-host>/admin/utilityConfigurations
For example, https://xxxxxxxx.oci.customer-oci.com/admin/utilityConfigurations
Operation: GET
Authorization: OAUTH2.0
For instructions on how to find the request URL, see Generate the Access Token.
To edit the configuration:
Get the response using a GET call.
Using the tables in this section, update the configuration and perform a PUT operation to the same endpoint with the entire object as the payload.
Available Configurations
The following topics describe the available configurations by integration point in Customer Experience for Utilities applications. The name in the first column is the {id} of the Utility Configurations to be updated.
In this section:
