Test Your Single Sign On Setup
The identity provider is now active and Single Sign On (SSO) is set up. Now you use Fusion applications to log in for both Oracle Fusion and Customer Cloud Service. All of your log in activities will go through the Fusion applications.
Now you will test your sign on in all systems.
Important Note: Oracle recommends creating and using test users to perform your SSO verification. If there are issues with your test, using your administrator credentials could result in your administrator being locked out.
This table outlines the steps required to create test users in each system:
| Create a Test User in This System | Details |
| Fusion Applications |
| Fusion Applications Identity Domain |
| Customer Cloud Service Identity Domain |
Using your test users, complete these steps to test your SSO.
To test the sign on in all systems:
Using the URL you received in your welcome email, log in to Fusion Applications as the test user.
Using the URL you received in your welcome email, log in to Customer Cloud Service as the test user.
If these attempts are successful, your test is complete.
Using the instructions provided in Set Up Fusion Applications Identify Domain as the Identity Provider in Customer Cloud Service Identity Domain, remove Username-Password from the Assign identity providers field. This removes the ability to log in with your local user name and password.
Parent topic: Configure Single Sign On
