Install and Configure Your Oracle Utilities On-Premises System
If you are using Oracle Utilities Customer to Meter as your customer information system, you must install and configure the system so that it will communicate with your Oracle Customer Experience for Utilities solutions.
For instructions on implementing Oracle Utilities Customer to Meter, see the Installation Guides section of the Oracle Utilities Customer to Meter library.
The current version of Oracle Utilities Customer to Meter runs with Oracle Fusion Middleware and Weblogic 12. The configuration of Weblogic should include Oracle Web Service Manager (OWSM). For details, see the Installing and Configuring the Oracle Fusion Middleware Infrastructure Guide, available in the Oracle Fusion Middleware library.
Additionally, you must verify that the persistent-store-type
element within the web application session-descriptor element is set to
replicated-if-clustered. For details on this setting, see Session Descriptor in the Developing Web
Applications, Servlets, and JSPs for Oracle WebLogic Server Guide.
After you complete the installation and configuration of your system, you must verify the following before continuing with the Customer Experience for Utilities implementation:
You have full administrator access to all systems used by your implementation, including the identity and access management solution used by your Oracle Utilities Customer to Meter system.
The Oracle Web Service Manager (OWSM) is available.
A detailed design plan exists before Customer Experience solution setup begins. Work with your Oracle implementation and delivery team to create this plan.
In this section:
