Manage Notification Preferences
You use the Notification Preferences section of the form to specify whether the contact is notified about specific types of information, and if so, what contact method is used for the notification. To add a contact method to a notification, that contact method must already exist for the contact. You can set notification preferences for any subscription-based notification types that are configured in your Oracle Utilities customer information system. Contacts must sign up to receive these notifications.
These are some examples of notification types that can be implemented:
- Credit and Collections
- Programs and Offers
- Service Advisory
- Bill Due
- Bill Ready
- Bill Routing Email
- Late Payment
- Payment Received
To set up notifications, you click the Enroll and add contact link next to an item. You then specify the contact method that should be used for that notification type. You can edit the notification preferences or turn them off by removing the contact method from the notification type.
Be aware that some notifications are mandatory and cannot be removed. To learn more about notifications, see Setting Up Notification Preference Options in the Administrative User Guide associated with your Oracle Utilities customer information system. Documentation for these systems is available in the Energy and Water Help Center.
Enroll in a Notification
To enroll in a notification:
- From the Customer Dashboard, select the billing account you want to work with in the header, and then select Update Communication Preferences from the Actions menu.
- The system opens the Set Communication Preferences drawer.
- In the Notification Preferences section of the screen, click the Enroll and add contact link next to the notification you want to set up.
- In the Send To field, select from a list of valid contact method records.
- Be aware that notification types can be configured to enable users to set additional parameters. For example, a notification can be configured to enable the contact to enter a value in the Day(s) before notification field, which controls when the notification is sent. For example, if you want to receive the Bill Due notification type 4 days before the billing due date, enter 4 in this field.
- Click the Enroll button to save your changes.
Parent topic: Setting Communication Preferences
