Defining Program Subscription Types
You use the Program Subscription Type portal to display and maintain program subscription types.
Refer to Understanding Program Subscription Types  for more information.
You can access the portal by selecting Admin, select Digital Asset Management, then select Program Subscription Type.
The following zones may appear as part of the portal's Main tab page:
  • Program Subscription Type List: This zone lists all program subscription type records. Broadcast a record to display the details of the selected record.
  • Program Subscription Type: This zone displays the selected program subscription type.
  • Attributes: This zone lists haracteristics that can be defined for program subscriptions of this type.
