Defining Accounting Calendars
The Accounting Calendar portal is used to display and maintain accounting calendars.
Refer to Understanding Financials for more information.
You can access the portal from Admin, select A, then select Accounting Calendar.
- Accounting Calendar List: This zone lists all accounting calendar records. Broadcast a record to display the details of the selected record.
- Accounting Calendar Display: This zone lists accounting period information about the selected account calendar.
