Defining Factors
The Factor portal is used to display and maintain factors.
Refer to Understanding Financials for more information.
You can access the portal from Admin, select F, then select Factor.
- Factor List: This zone lists all factor records. Broadcast a record to display the details of the selected record.
- Factor: This zone displays information about the selected factor.
- Factor Values List: This zone displays the factor values that are applied to the factor, the date and time the factor goes into effect, and the tax component used to calculate the tax values.
