Defining Storeroom Types
The Storeroom Type portal is used to display and maintain storeroom types.
You can access the portal from Admin, select S, then select Storeroom Type.
  • Storeroom Type List: This zone lists all storeroom type records. Broadcast a record to display the details of the selected record.
  • Storeroom Type: This zone provides information about the selected storeroom type.
