Defining Storerooms
The Storeroom portal is used to display and maintain storerooms.
Refer to Understanding Inventory for more information.
You can access the portal from Admin, select S, then select Storeroom. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
- Storeroom: This zone provides information about the storeroom, such as address information, accounting information, reorder information, and so on.
- Current Activities: This zone provides summary information about activities that are currently associated with this location.
- Asset Summary: This zone displays statistical information about the assets associated with this location.
- Attachments: This zone enables users to manage all types of attachments for the storeroom record.
