Configuring GIS Integration
Follow the configuration steps described in the following sections to enable the GIS Integration functionality. Refer to Understanding GIS Integration for more information.
Note: This integration requires several installation steps to be performed
in Esri ArcGIS prior to the configuration steps described here. Refer
to the Installation Guide for more information about the Esri
ArcGIS integration components.
