Operational Reading Alert Review
The Operational Reading Alert Review portal is used to review operational reading alert records.
You can access the portal from Menu, select Asset Management, then select Operational Reading Alert Review. You are brought to a query portal with options for searching for operational reading alerts by measurement type. Select the appropriate reading alerts and click the Remove Alert button to remove the alert.
