Defining Labor Earning Types
The Labor Earning Type portal is used to display and maintain labor earning types.
Refer to About Timesheets for more information.
You can access the portal from Admin, select L, then select Labor Earning Type.
- Labor Earning Type List: This zone lists all labor earning type records. Broadcast a record to display the details of the selected record.
- Labor Earning Type: This zone provides information about the selected labor earning type, including adder and multiplier values.
