Deploying the Jar File
To deploy the jar file:
- Download the Oracle Utilities Work and Asset Management V2.4.0.1.1 ESRI Integration component from the Oracle Utilities Work and Asset Management V2.4.0.1.1 package.
- Copy the file to the server where ArcGIS is installed and unzip it.
- Navigate to the /GPService/lib/spl-w1–2.4.0.1.1–gis.jar file.
The deployment of this jar requires ArcGIS Desktop (to execute the jar and generate the results) and ArcGIS Server (to publish the results as Geoprocessing service). Extract the additional jar files jackson-annotations-x.x.x.jar, jackson-core- x.x.x.jar, and jackson- databind- x.x.x.jar from the below ArcGIS Server installation location.
<ArcGIS Server Installation Path>\Server\framework\lib\shared
(Ex: C:\Program Files\ArcGIS\Server\framework\lib\shared)
It helps the extractor program to access the map/feature services if they are secured.
Note: If using ArcGIS Server 10.9.1 and ArcGIS Desktop 10.8.2, download the
GIS JAR file that is part of the patch provided for the BUG 35212608 and use that JAR file
instead of the one provided in the WAM 2.4.0.1.1. package. Also, do NOT place the additional
“jackson-annotations-x.x.x.jar”, “jackson-core- x.x.x.jar”, and “jackson- databind- x.x.x.jar”
jar files as described above.”
These jar files should be placed in the following ArcGIS desktop
and ArcGIS server running locations:
- ArcGIS Desktop installation folder path
Example: C:\Program Files (x86)\ArcGIS\Desktop10.8\java\lib\ext
- ArcGIS Server installation folder path
Example: C:\Program Files\ArcGIS\Server\usr\lib\ext
