Executing the Tools
To create and execute a new/custom tool:
- Open the ArcMap or ArcCatalog application.
- In the Catalog window, navigate to Toolboxes and then click My Toolboxes.
- Right-click My Toolboxes and select New and then click Toolbox.
- Enter WAMGPTools.tbx as the toolbox name and click Enter.
- Richt-click the new toolbox and click Add and then click Tool.
- In the Add Tool dialog box, select WAMGIGPFF and click OK.
- To execute the Extract_Delta_Changes tool in ArcToolbox:
- Select and double-click the tool.
- View the tool's parameters.
- Provide the respective inputs to the parameters:
- Task_Name: QueryIDs
- Execution_Mode: Initial
- Feature_Class_List
- Example: SDE.wControlValve
- Source_Version: SDE.DEFAULT
- Temp_Version: Temp
- WKID: Well-known identifier for the target spatial reference
- WAM Sync Version: The version name to be created in Geodatabase to track incremental changes
Example: WAMSyncVersion. Leave the remaining parameters as “NA”.
- Click OK to run the tool.
- To execute the Generate_Token tool in ArcToolbox:
- Service_URL: URL to the ArcGIS Server REST Service
- Protocol_Type: Select W1RT for Rest Service and W1SP for SOAP Service based on the service used in above parameter
