Seasonal Normative Comparison
The Seasonal Normative Comparison module compares the customer's cooling or heating energy use from the previous season compared to other homes. This comparison motivates them to reduce cooling energy use during the upcoming extreme weather season.
Appears in: Seasonal Report
Seasonal Normative Comparison Example
The image below is an example of the Seasonal Normative Comparison module.
Image of the summer Seasonal Normative Comparison module
Configuration Options
For each element listed in the table, indicate the desired configuration in the Input Value column. If you do not provide an input for optional configurations, the default will be used.
Configuration Option Input Value
Explainer
This text appears below the graph and defines the season date range.
Default: Based on utility seasonal date ranges.
Optional
Choose one of the following:
User Experience Variations
The user experience varies for customers depending upon their service types, available data, costs, and locale. For more information, see the Seasonal Normative Comparison topic in the Oracle Utilities Opower Energy Efficiency Cloud Service Overview.
