Mini Time of Use Reminder
Positioned in the top right of the progress version of the Peak Focused Report, the Mini Time of Use Reminder module is a customer's first point of reference for understanding peak electricity cost periods based on their Time of Use plan. The module clearly displays the multiplier for high-cost periods and their specific timings., provides a color-coded timeline that highlights peak times in for easy identification, and adapts to different utility peak times and billing structures, such as demand charges.
On this page:
Requirements
Utility Requirements
Category |
Description |
Required Cloud Service |
Energy Efficiency Cloud Service |
Scale |
Less than 100,000 per week. |
Customer Requirements
Category |
Description |
Billing Frequency |
Monthly or bi-monthly. |
Data Delivery Frequency |
Monthly, bi-monthly, or quarterly. |
Data Requirements |
Data History |
A minimum of one historical bill. |
Data Coverage |
Not applicable. |
Supported Fuels |
Electric-only. |
Limitations
- Peak Focused Report Only: This module is only available as part of the Peak Focused Report.
- Time of Use: Customers must be on a Time of Use Rate plan.
User Experience
This section describes the user experience for a customer with three peak times.
User Experience Variations
Configuration Options
For each element listed in the table, indicate the desired configuration in the Input Value column. If you do not provide an input for optional configurations, the default will be used.
| Configuration Option | Input Value |
Header The header informs the customers what the multiplier in cost will be during the peak period and what times the period will occur. Default:
Optional Choose one of the following:
Color Settings Color settings determine the colors assigned to elements within the module. Default: The default module colors are determined by the utility color pallet provided by the utility during Opower Platform configuration. |
Optional
Footnote An optional footnote may be included under the cost period legend. Default: The footnote is disabled. |
