Environment Assessment
Environment assessment allows administrators to perform basic validation of correct installation of Oracle Utilities Application Framework Home target page.
The following files, settings, and definitions are checked:
- Correct positioning of key files
- Key configuration settings
- Correct setting of security definitions
- Patch validation
To assess the current environment:
- Open the Oracle Utilities Application Framework Home target page. On the Target dropdown, choose
Figure 1. OUAF Home Target page: Assess
- On the Credentials page, choose a set of saved credentials or enter your user name and password, then click Next to proceed.
- You will be directed to the Job Activity page, where you can view the results of the assessment job.
Figure 2. Environment Assessment: Result
- Click Finish to return to the Oracle Utilities Application Framework Home target page.
