Viewing Logs
The View Logs feature allows you to view the contents of log files, including the latest thread pool worker log, that are generated at the application server level.
To view logs:
- From the appropriate Target Home Page (Web Application, Web Services, or Batch Server target home page), choose
Figure 1. Viewing Configuration Logs
- On the Credentials page, choose a set of saved server credentials or enter your user name and password, then click Next to proceed.
Figure 2. Specifying Credentials
- The Log Info page offers a selection region to let you choose from among all available logs, as well as a display area for the selected log.
Figure 3. Log Info page
- Enter the number of lines that you would like to view from the selected log. If no value is entered or the value exceeds the number of lines in the selected log, the complete log is displayed.
- Click Submit to display the log in the scrollable text area.
- After viewing the selected log, you can select other logs to view, or click Cancel to return to the Target Home Page.
