Post-Promotion Tasks
The following tasks are required after a target is promoted.
  1. Configure monitoring credentials. This task creates the monitoring credentials for the web application, web services, and batch server targets. It involves navigating to Setup, and then Security, and then Monitoring Credentials and enter the JMX credentials for all three target types. For example, the following steps configure the credentials for the batch server. Follow the same steps for the web application and web services targets.
    1. Select the target type and click the Manage Monitoring Credentials button.
      The Manage Monitoring Credentials button initiates the creation of the monitoring credentials for the web application, web service, and batch server targets.
    2. Select the target and click the Set Credentials button.
      The Set Credentials button facilitates the data entry of JMX credentials for the selected target.
    3. Enter the JMX credentials. This should match the JMX credentials of the OUAF environment.
      The JMX credentials must match the JMX credentials of the Oracle Utilities Application Framework environment.
    4. If you prefer to use Rest API option, enter the JMX http credentials. This should match the JMX http credentials of the OUAF environment.
    5. Repeat for the Web application and Web services targets.
  2. Set up monitoring configuration. For all Framework version 2.2.0-based environments, ensure that the target monitoring configuration contain the appropriate settings for Java Home and Oracle Home, Web Server Home and Web Server Java Home values. These are the environment variables that are set in the host before you run splenviron.cmd/sh. Note that Web Server Home is the location on which the WebLogic software is installed (e.g., /spl/middleware10.3.3./wlserver_10.3). Web Server Java Home is the Java location that is used as JAVA_HOME by the Web Server. For WebLogic servers on Linux, it is same value as JROCKIT_HOME. Set up monitoring configuration for all target types.
    1. For example, to setup the monitoring configuration for the batch server, first click on the target drop-down on the upper left, then choose Target Setup, and then Monitoring Configuration.
      Select the Target Setup and the Monitoring Configuration menu items to start setting up the monitoring configuration for all the environments.
    2. Then enter the appropriate information:
      The monitoring configuration must include the appropriate settings for Java Home and Oracle Home, Web Server Home and Web Server Java Home.
    3. Repeat for the Web application and Web services targets.
